Labview and Autocad
How can i connect labview with autocad? Anyone got any ideas?
Cheers
Mau
(3,921 Views)
Never tried connections with autocad but the usual method of interfacing with outside applications are (Windows OS) through activeX automation or dll calls.  This depends on what services the application provides (if any).  Also documentation is usually scarce in either case.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,900 Views)
As an old AutoLISP hacker, I am curious what you are trying to do.  Like falkpl mentioned, there are several activeX components availible for Autocad, but it is poorly documented and not very complete.
(3,886 Views)
I recently posted an example project that shows how to connect LabVIEW to AutoCAD using .NET
https://decibel.ni.com/content/docs/DOC-38857
Jannis
(3,365 Views)
