Desktop PC for ETS target
I've tried to use my DELL Pc as en ETS target. But it's failed due to the ethernet chipset.
My Dell is an Optiflex 170L with a Intel PRO/100 VE Network.
I thought that board is compatible with your OS (I've checked it on your list). Is it true?
Could you give me a list of compatible DELL computer?
Thank you
Message 1 of 9
(4,964 Views)
Hi Fred
You can test the compatibility using the following procedure:
http://digital.ni.com/public.nsf/allkb/82D66505D86349F38625722C00736AB8?OpenDocument
We don't have a list of supported computers ( processor, ethernet chipset, bios settings, ram & motherboard requirements affect compatibility) but you can
find out more at:
https://www.ni.com/en/support/documentation/supplemental/08/requirements-for-desktop-pcs-as-phar-lap...
KostasB
Applications Engineering
Message 2 of 9
(4,955 Views)
I've already read this 2 documents.
And in the second one (https://www.ni.com/en/support/documentation/supplemental/08/requirements-for-desktop-pcs-as-phar-lap...), my ethernet board "Intel® Pro/100 VE "0x1032, 0x103D"(8.5+)" is notified as supported.
But when i used the evaluated software, I've got an error about my ethernet board. So I don't understand where is the problem.
Fred
Message 3 of 9
(4,945 Views)
I do not think we have an evaluation copy of LabVIEW Real time. Are you positive that you are using a copy of the LabVIEW 8.5 Real Time Module (ETS)?
KostasB
Message 4 of 9
(4,927 Views)
No, I don't use a evaluation copy of Labview RT. But I used the PC eval software (pceval.exe) to indicate if my PC is compatible or not.
Fred
Message 5 of 9
(4,925 Views)
Sorry about that- I just thought you might have the wrong software.
Two questions:
Is the computer under test  connected to a network with a running DHCP server during testing?
Does the motherboard support both 3.3V and 5V power rails?
Thank you,
Kostas
Message Edited by KostasB on 12-04-2007 09:25 AM
Message 6 of 9
(4,918 Views)
I will make a comment about pceval, it sometimes returns erroneous results. I'm not sure whether it has been update recently, but when I ran it on our PXI based system using a Kontron CP307 dual core processor it gave a compatibility problem message with the SATA hard drive. This compatibility was corrected in 8.5, but doesn't show up as such in the pceval, so if the written documentation indicates compatibility and the pceval says otherwise, it still may be ok.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 7 of 9
(4,916 Views)
     I will have to agree with LV_Pro on this case of the pceval.exe software.  When I used it to build my Real-Time system I used the pceval software and to me it seemed a little out of date an no descriptive.  I am not sure what the latest update of the software is but on the page where it states to download the software it says "Primary Software Version: 8.2" so it is probably not even looking for new 8.5 compatibilty ethernet cards.  So I would try to get my hands on a trial version of LabVIEW and the Real-Time Module from your local NI representative.  I hope that helps.
Michael B
Message 8 of 9
(4,859 Views)
I've tried to install the ETS RT OS on my Optiflex 170L. This installation failed to due the network.
But, I've found a network PCI board with an intel chipset. And It's working with this board. So I've got a RT target for my test.
Thank you for your help
Best regards.
Fred
Message 9 of 9
(4,844 Views)
