Detect Dial Needle finished value changing?
Hi all,
Is there any way of detecting when a Dial Needle has finished changing value?
I'm trying to create a VI to request a bearing change.
I don't want to swamp the control unit with a request for each change in the Dial Needle so I'm using Mouse Events.
I can use Dial: Mouse Up and Dial: Mouse Left to request a new bearing change.
However, you can still move the Needle when it is outside the Dial, which does not result in a bearing change request.
I've attached my VI and any help would be gratefully appreciated.
Phill
(2,941 Views)
Accepted by topic author tadders
How about just detecting the events and updating the indicator.  I've added "Pane: Mouse Up" to update the indicator if the mouse leaves the dial before dropping the needle.  This'll add a nuisance update when the Pane: Mouse Up occurs due to something other than a needle move, but you can detect that by checking for a change in Bearing Dial value.
Jim
(2,915 Views)
Thanks Jim, just the job!
Phill
(2,899 Views)
