Show Control Panel of Icon Used in Block Diagram...Possible???
Suppose that you realize a subVI_1 with its icon.
After you use this subVI_1 in an other VI_2.
It's possible to show in the main control Panel of VI_2 the control panel of VI_1???
How can show popup message of error or advise???
It's possible show intermitted light like dangerous alredy done??
It's possibile to extend the design of control panel??? With other icons, other figures, etc...
(2,727 Views)
If I understand your question correctly than yes you can show your subvi front panel in your main vi. Go to vi properties --->Windows appearance--> (choose) open when called .
(2,705 Views)
Hi Laura!
If you need to show the controls of the subVI into the panel of the mainVI, you have just to replicate them into the mainVI front panel and connect
them to the subVI trought the connection pane.
MarcoMar
National Instruments Italy
(2,681 Views)
