Detect edge locations on a digital waveform
could you please explain the XOR sweep method in more details ?
Message 11 of 12
(721 Views)
XOR will return true if the two arguments are different. Run this on consecutive elements of your digital signal and you'll end up with markers for where the transitions occurred. You can then use your waveform start and dt information to get the times.
Message 12 of 12
(708 Views)
