Detect how long a boolean is true
@kartiknattar wrote:
I guess this might help you.
Ohh thank you! But what I have to write in the both false case?
Message 11 of 19
(2,216 Views)
This vi will help you. Mark as solution if it works
CLD Using LabVIEW since 2013
Message 12 of 19
(2,212 Views)
It is not what I ask 😕 I try to explain better:
1) I have a boolean as control;
2) After I push the control I would like that a timer start;
3) If this boolean remain true for more then 2 seconds an indicator (led) lights on;
4)When the boolean return false, the led lights off and the timer return to zero;
5)When the boolen is true again the whole cicle will start again;
I hope so much that you could help me!
Message 13 of 19
(2,206 Views)
Hi mb,
you already marked a solution to your question, so why do you need a new thread to discuss the very same problem?
Message 14 of 19
(2,202 Views)
Accepted by topic author mbindustry
Here's what I would probably do:
Message 15 of 19
(2,201 Views)
cause I am wrong
Message 16 of 19
(2,200 Views)
thank you! It was of help but I would like that after 2 seconds the led lights on, not in the same moment of the boolean
Message 17 of 19
(2,191 Views)
done! Merci!!!
Message 18 of 19
(2,189 Views)
A simple ">2" comparison in the time difference will do that.
Message 19 of 19
(2,180 Views)
