Determine position of a signal part on a graph
Hello everyone,
I have a problem. I have to determine position of a signal part on a graph. Then I have to determine maximum value of that part (this is not a problem).
Signal have a lot of noise. I have done some filtration but again signal have noise. Regard to that, filtration change signal, so later when I take a measurement, there is possibility that this is not true value.
Does anyone have idea how to determine position of a part of a signal automatically, for different (similar) signals.
There are attached pictures where is marked what is part of a interest on a signal. There is a VI where is a one signal for testing.
(2,411 Views)
You might want to start with some tutorials.
The next thing to look at is the Peak Detector.vi.
(2,407 Views)
Accepted by topic author Laza22
From the screenshot I understand that you interested only in the local maximum of the signal.
There is a VI that detects the Peaks when you specify a certaing thershold and the width of that maximum point.
Later on, it is just a matter of defining the value of you local maximum. Basically you will have to thershold again the 1D array obtained from that VI.
I am attaching a VI that can be a good starting point for your application.
Ion R.
(2,393 Views)
Thanks ion.rosca
This is the solution
(2,380 Views)
Thanks Taki1999
It is a solution.
(2,377 Views)
