Electrical generation on cRio
I'm looking to write a control program for my reactor system, and I'm controling flow rate. I have the pump (0-10vDC), but I can't figure out how to generate, or modulate the voltage. I am using a cRio, and I'm using the scans platform, so I can't use DAQ. Could you please advise.
(2,397 Views)
Accepted by topic author BioProcessNU
Hello BioProcessNU,
There are multiple Analog Output modules for the cRIO. The type of module you should use depends on how many channels you need. I have included links to a few of National Instruments cRIO Analog Output modules.
Here is a link to the four channel Analog Output Module.
Here is a link to the sixteen channel Analog Output Module.
Here is a link to the sixteen channel Analog Output Module with channel isolation.
Wear
Product Support Engineer
(2,379 Views)
