Determine the size of a cluster in memory
In additional:
Here is the document How LabVIEW Stores Data in Memory
best regards,
Andrey.
Message 11 of 13
(783 Views)
tst wrote:
When you put all of them together in a cluster, the total amount of memory needed to hold the data in the cluster is the sum of those numbers.
This means that LV has only a Struct datatype, and not a Union datatype, like that of in C.
Am I right?
- Partha ( CLD until Oct 2027 🙂 )
Message 12 of 13
(777 Views)
Yes, you're right.
For example, we have following cluster:
Then in memory this construction will be represented like this (refer to doc above):
Flattened to string cluster then looks like this:
I hope this explanation will be helpful for understanding.
Andrey.
Message 13 of 13
(765 Views)
