Difference between Buffered Read and Read Mode on DataSocket Open
What are the behavior differences when opening a DataSocket connection with a Buffered Read verses Read?
(2,927 Views)
Mlenz,
You can learn about buffering data from our website, or in the LabVIEW help.  By using the Datasocket Buffered Read, you are enabling Client-side Buffering.  If you do not use a Buffered Read, then the LabVIEW does not store the values in a buffer, which are written when the value changes.
Hope this helps,
TheDillo
(2,918 Views)
