searching through a table
hello,
what i have is a table with binary strings.  i am seaching through the table to find matching strings that the user inputs.  i use a for loop but i need a way to do a few options.
1. i know there is a way to use the for loop without having to specify a "N" value but is the way i am doing it sufficient.
2.  my program is not highlighting all the occurences, it is skipping some occurences
3.  search for 1st occurence
4  Go to next occurence
5.  Find all occurences
6.  an option to clear the table and the table selections.
i attached a vi that does the searching but that's about it.  thank you in advance
(3,481 Views)
SInce you don't know how many elements will match, you must use a while loop, not a FOR loop.
Simply reshape the array to a 1D, the use search 1D array until you run out of elements. Attached is a quick sketch (LAbVIEW 8.0), see if you can take it from there. It also shows a way to reset all table backgrounds to white. 😄
(There are many other ways to do this.)
(3,470 Views)
thank you for the help
(3,445 Views)
If the number of matching elements are known, how would this VI be arranged with a For Loop?
(3,370 Views)
  1. replace the while loop with a FOR loop
  2. wire the known item number to N
  3. remove the case structure, leaving only the code in the default case.
  4. everything else stays the same.
(3,362 Views)
