Difference between Channeled Message Handler and Queued Messange Handler concepts
What are the main differences between the CMH and QMH design patterns? Both are available as project template, but I cannot really find any documentation about the main differences, and about when to use one or the other.
I've looked on the block diagrams, and they are quite similar. But there are some differences as well, which I don't really understand.
Tamas
Message 1 of 12
(6,055 Views)
Tamas
As you may have guessed the two are different flavors of the same thing, used in the same way, for the same things.  Some say that it is more in keeping with the dataflow paradigm because you have actual wires connecting things instead of data disappearing into one VI (enqueue) and coming out another (dequeue).
I've not seen wide adoption of channel wire technology, probably because it is relatively new, has a fair learning curve, and (IMO) has some quirks that can get you into trouble if you're not careful.  On the other hand, once you get the hang of it, it really does make more sense than queues.
I haven't really adopted it because queues have always worked for me, and aren't bothered by them enough to seek a new way to do an old thing.
Bill
CLD
(Mid-Level minion.)
Message 2 of 12
(6,052 Views)
Thank you Bill for your reply.
I am slightly enlightened, and slightly confused as well ;).
As far as I can see, the CMH and QMH both using the enqueue/dequeue VIs to 'communicate' between the two handler loops. But you say that these are 'wire based' instead of queues.
Do I misunderstand you?
Tamas
Message 3 of 12
(6,043 Views)
I have been using Channel Wires since before they were introduced "publicly" in LabVIEW 2016.  I gave a talk at NI Week a few years ago, where I said that they were a "better metaphor" for Asynchronous Communication than were Queues, and they had a few features that "improved" on the use of the original "Synchronization" functions (for example, the Stream is, I believe, much superior to the Queue for a Producer/Consumer design as it includes a "reasonable" Producer-to-Consumer method of dismissing the communication channel).
Regarding the Example Code that comes bundled with LabVIEW, I (personally) find the QMH and CMH examples confusing and "overly busy".  Within the last month or two, I've posted (I think) "simplified" versions of the CMH in this Forum that "does one thing", namely implements a CMH model of a State Machine.  I should be able to find it, but it may take me a few days ...
Bob Schor
Message 4 of 12
(6,017 Views)
Hi Bob,
Thanks for your reply as well!
In the meanwhile I was looking into the samples. And I started to understand the CMH example. For me it is simply a producer/consumer design, where the control data transfer is based on a queue. And on the top of this there is this green channel wire that is only being used by the Message Handling Loop to inform the Event Handler Loop to terminate. If you use the Exit button, it is not even needed as the "Exit: Value Change" event will terminate the Event Handling Loop anyhow.
So I try to ignore this channel wire when I try to understand it example.
With the QMH example I still struggle a bit. I just don't get that User Event Stop vi and its wires.
I also discovered that the Core2 course has an exercise about Design Patterns (Exercise 2), and one of the examples there is a simple Producer/Consumer setup, without any fancy channel or event wires between the Producer and Consumer loop:
Maybe I just stick with this, instead of CMH or QMH...
Message 5 of 12
(6,010 Views)
@tcsabina wrote:
This is a very strange example!  Did you notice that the Communication between the Event Loop and the "Message Handler Loop" is a Messenger Channel Wire?  [You can tell it is a Channel Wire because it "looks like a Pipe", and can distinguish it as a "Messenger CW" as opposed to a "Stream CW" because it can branch].  It even shows the Channel Writer, but for some unknown reason, the Channel Reader is "hidden" inside a function called "Dequeue Message.vi"!  But there is no Queue, and hence no need to "dequeue".
If this was supposed to be an example of a Producer/Consumer Design Pattern, the wrong kind of Channel Wire was used (IMHO).  Producer/Consumer (in its purest form) relies on one Producer talking to one Consumer over a channel that does not branch.  That's the Stream Channel, which has several very nice "designed-in extras" that facilitate the proper shut-down of the Stream through the use of the "last element?" and "Element Valid" terminals on the Reader and Writer.
Bob Schor
Message 6 of 12
(5,976 Views)
No, I didn't notice that. Thanks for pointing out! It is indeed an example for the Producer/Consumer concept:
https://learn.ni.com/learn/course/creating-an-event-driven-user-interface-in-labview/creating-an-eve...
So the CMH is using a Channel to communicate between the 2 handler loops.
The QMH is using a Queue for this.
And the example in Core2 is also using a Channel. Correct?
Tamas
Edit:
There is a new version of Core2, but it seems that this particular example still using channels:
https://learn.ni.com/learn/course/producer-consumer-events-design-pattern/producer-consumer-events-d...
Message 7 of 12
(5,951 Views)
Hi Bob
where did you get this program? i tried to find them because i am taking the Core 2 and i don't have access to these programs.
Message 8 of 12
(2,511 Views)
Where did I get what program?  I responded to the Original Poster, who had a picture of some code (which didn't make much sense to me).
For what it is worth, most of the code I'm writing these days uses my Channel Message Handler (CMH) to drive the main "state machine" loop, with a cluster consisting of "State" (an Enum) and "Arg" (a Variant, often empty) with an Error Handler sitting on the Error Wire between the State Machine case structure exit and the While Loop exit that traps Errors (routing the "Next State" to the Error State, with an Argument consisting of the Error Line before being Cleared and the contents of the "Next Message" as the "Arg").  I use a Stream Channel when I need Producer/Consumer parallel loop execution (and many times, the Consumer is also a CMH).
Bob Schor
Message 9 of 12
(2,475 Views)
As Bob mentioned above CMH and QMH are basically the same except for some minor differences.
Personally I find Channel Wires easier to understand and work with as they do not break the data flow paradigm in my mind like Queues and Notifiers do.
I gave up on the QMH design pattern as it was so tightly coupled that making one little change blew-up the whole thing. I ended up designing my own CMH from scratch based on Bob's example. I use a "Lossy Stream" channel as a measurement buffer to hold the last 10 seconds of data to dump to a file if the test is aborted due to exceeding safe operating limits. I use a Messenger Channels with a "command" and optional "variant payload" for communicating and passing data between loops.
=== Engineer Ambiguously ===
Message 10 of 12
(2,433 Views)
