LV2024 remote debug fails to connect
Running LabVIEW 20214 on Windows 11. Debug application works when local.
Accessing over network:
Debug port 3580 open on incoming and outgoing both machines
Both machines have UDP and TCP on port 3580
Networks: Domain, Private and Public enabled
Using Wireshark to capture packets i receive
GET National Instruments LabVIEW Built Application 24.0 RemoteDebug TX TEST STATION - CGR.EXE NI.LV.AutoLaunch? HTTP/1.0
This shows the debug request is received and the remote responds with the name of the running application to be debugged.
Development system reports no debuggable application is found. Allow debugging check is enabled in the executable as I can debug if I run it locally. To eliminate any discrepancies between runtime engine and development version the do not allow newer runtime version to execute the build is checked so we will always be on the same versions.
Where to check next to get this functionality working?
Ideas? Suggestions?
I want to exhaust LabVIEW efforts so I have data points before engaging Corporate IT.
Message 1 of 1
(224 Views)
