Labview Installation Freezing during Offline Manual
I am currently trying to install Labview 2025 Q1 on my company's workstation and keep getting hung up during a portion of the installation pertaining to the Offline Manual:
Looking around, I found the thread (https://forums.ni.com/t5/LabVIEW/installing-problem/td-p/4290941) that closely pertained to my issue, but following the instructions on ending the task leads me to the following message every time:
Any help would be really appreciated!
Message 1 of 30
(7,175 Views)
Any success on this one? Having the exact same issue. Have tried the 'solution' in the link, tried on- and off-line installs. Same issue.
Message 2 of 30
(7,104 Views)
I had same issue and that "End Task" did not help as you mentioned. I solved that by going to windows Apps, first uninstalling the package manager and then uninstall NI software. Thereafter, started a new setup and using the task-manager "End Task" on the offline help worked fine.
Message 3 of 30
(7,070 Views)
I got past this by opening a command prompt in admin mode and then run "taskkill /f /im niofflinehelpviewer.exe"
the odd part is I get a confusing message at the end
Message 4 of 30
(6,918 Views)
Yup, this worked for me, thanks! Had the extact same issue and spet 2,5 days on reinstalling. Had to end the task about five times tho, since I guess the OFFLINE MANUAL has 5 different components, all of which hang the installer. Sometimes the task would show up in the task manager and sometimes I had to use cmd.
Message 5 of 30
(6,900 Views)
@ThaiDo345 wrot
I got this error when killing from the task mgr.  Using command prompt does not have this issue.
Message 6 of 30
(6,883 Views)
NI requests your log files to help diagnose the issue with the offline help viewer installation. They are located at C:\Users\<username>\AppData\Roaming\ni-offline-help-viewer\logs
We are currently tracking this issue with Bug 2090695.
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 7 of 30
(6,830 Views)
See attached
Message 8 of 30
(6,810 Views)
Is there a way for us to track bug 2090695? This issue has been plaguing us for a while and would like to know when its resolved. Thanks.
Message 9 of 30
(6,569 Views)
We're now tracking this with Bug 3140514.
The problem seems to be with the offline.sqlite file, and a possible workaround is to delete it before running the installer. The file is located in C:\ProgramData\National Instruments\Offline Help Viewer\database-orm
We don't currently have a way to share the status of a Bug until it is resolved, in which case it would appear in the Bug Fixes document for a release.
Christina Rogers
Message 10 of 30
(6,548 Views)
