Labview Installation Freezing during Offline Manual
"The problem seems to be with the offline.sqlite file, and a possible workaround is to delete it before running the installer. The file is located in C:\ProgramData\National Instruments\Offline Help Viewer\database-orm"
we have been updating at work and this solution worked for one of our pc's.
thank you so much.
the "taskkill /f /im niofflinehelpviewer.exe" worked as well for mine.
Message 11 of 27
(863 Views)
@Christina_R wrote:
We're now tracking this with Bug 3140514.
We don't currently have a way to share the status of a Bug until it is resolved, in which case it would appear in the Bug Fixes document for a release.
Another symptom, it also gets stuck when removing packages as well.
Message 12 of 27
(844 Views)
Has bug 2090695 been fixed yet?
Message 13 of 27
(765 Views)
No, sorry, we're still working on the offline help issue. (Note, though that we're now tracking this issue with Bug 3140514).
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 14 of 27
(753 Views)
moving that offline.sqlite out of the folder "C:\ProgramData\National Instruments\Offline Help Viewer\database-orm" allowed the install to complete. Thanks for the suggestion.
Message 15 of 27
(739 Views)
This is what we call a showstopper in my domain. When will there be a fix for this? I can't install LabVIEW.
Message 16 of 27
(680 Views)
why is it a showstopper if work around is available?
Just use the steps described previously and it will work.
Message 17 of 27
(673 Views)
Workaround didn't work for me (tried to remove the database folder as recommended previously), but I did find a new one. Unchecked the offline manual from the list of many other recommended components that were pre-selected. By skipping that install, installation proceeded normally.
Message 18 of 27
(670 Views)
Would you be willing to send me the log file from the failed installation? It would be in C:\Users<username>\AppData\Roaming\ni-offline-help-viewer\logs
Christina Rogers
Message 19 of 27
(595 Views)
I got the "An internal error occurred. Value cannot be null. Parameter name: key" from using the latest NIPM online install for LabVIEW only (some additions may trigger the offline help error freeze) after choosing to check for update. the same error also happen with the offline iso
CY (expired CLAD)
Message 20 of 27
(512 Views)
