Difference in UNDO behavior while closing the file
Kindly follow these steps. Please explain whether it is the expected behavior.
1) Select a new VI and drop any function in the BD and UNDO the operation. Close the file, LabVIEW prompts "Save changes before closing?"
2) Select a new VI and drop a vi using "Select VI" and UNDO the operation. Close the file, LabVIEW will close without any changes notification.
(3,659 Views)
If you make 1 change and then undo that single change, wouldn't you expect that 0 changes have been made (1-1=0)? I see nothing abnormal about this behavior.
(3,657 Views)
Thanks for the response Dennis sir, the above point is OK for case 2. But in case 1 when in a new VI , i placed a for loop and UNDO that and when i closed the file, it asks for saving changes. ????
Mathan
(3,654 Views)
Okay, sorry I missed the first part.
I actually sometimes see the behavior when using the select function as well. Don't see any reason for this but I would be hard pressed to call it an actual bug. What version of LabVIEW are you using?
(3,644 Views)
Thanks for the response. Am using LabVIEW 2009 f2.
(3,636 Views)
Any explanation for this bahavior from blue people? Is it a bug or not? I will close this thread based on any feedback from blue people.
(3,565 Views)
