How to close running applications listed in Application tab of Windows Task Manager
Hii,
I am using Labview7.0. I want to close all running applications except my labview based exe in Applications tab of Windows Task Manager. So pl help me how can I do it through labview7.0 Programmatically.
Vijtin....
(4,878 Views)
You can use the utilities attached, when you unzip it you can open the lvwutil32 folder and then you will find Winevent.llb inside it is the Quit Application.vi  is very easy. There is also a Get Task List.vi which help you too.
I hope this info will help you, let me know if you need more help
AJJR
(4,872 Views)
Hii
Thanx for sending file but I can not use it becz It is 8.2.1 version of Labview & I am using LabVIEW7.0. So pl send me solution in LabVIEW7.0.
Vijtin....
(4,819 Views)
You can download it yourself from here.
(4,803 Views)
