VI's in Sound and vibration toolkit
I apologize, I'm beginner. Can i find this VI in Labview: http://zone.ni.com/devzone/cda/tut/p/id/4989  and just use it, or I must create it myself.
Also, I have the same question for VI's showed in http://home.agh.edu.pl/~robertb/zajecia_dz/SVT_User_Manual.pdf.
Thanks in advance
Stjepan
(3,281 Views)
The integration VIs are sold as part of the Sound and Vibration toolkit.  They are optimized and proven to work for integrating acceleration to velocity and displacement.  They are created out of LabVIEW Full Development System, so could be recreated, with significant effort in development and testing (and of course responsibility that you get it right).
You can download an evaluation copy of the tools.
https://www.ni.com/en/support/downloads/software-products/download.labview-sound-and-vibration-toolk...
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,252 Views)
I understand, and I have the Sound and Vibration Toolkit, but I cannot find this vi which is shown on http://zone.ni.com/devzone/cda/tut/p/id/4989  on figure 1. I Can find all the blocks inside separately, must I now use all of them to manually make the VI?
(3,242 Views)
On the Sound and Vibration pallette in LabVIEW, there are Sound and Vibration express VIs.  On the second row, first item is level measurements.  On this sub pallette, you will find sound level and vibration level.  The vibration level express VI also performs integration.  You can export the integrated signals.
So it is all done for you in the express VI.
Preston Johnson
cbt
512 431 2371
(3,231 Views)
