Different Labview architectures
Hi
What are the different types of architectures used in LabVIEW other than state machine architecture?
(10,431 Views)
• State machine and queue driven message handlers that are based on the producer/consumer design pattern
• State machine as client/server
• Functional global variables
• Plug ins with VI Server
• Plug ins with LVOOP
• Reentrant VIs
• Graphical Object Oriented Programming
Message Edited by muks on 01-02-2010 03:32 PM
(10,423 Views)
The most important after state machine is producer/consumer (mostly it's queue based, but also can come with notifiers or user events).
In combination with the state machine they form the group of message handlers, a nice presentation is on expressionflow.
To create an indepent parallel process was called 'demon' design pattern, a recent presentation here.
OOP has an established set of design patterns (search for 'Gang of Four' GoF), most of them are also possible in LVOOP, see here
And you can use bus-style messaging such as this.
This is a large set for reading, but there are even more concepts/implementations around. For the latest discussions you can browse on LAVA. Will be enough to read for this year...
Felix
(10,411 Views)
swathi wrote:
Hi
What exactly are you trying to find out?
(10,372 Views)
