How can I detect if LabVIEW is the active (frontmost) Windows application?
I need a way to figure out in LabVIEW 6.1 if LabVIEW is the "active" application in Windows. More specifically, I need to know if a user has switched to some other application besides LabVIEW. This needs to work on an EXE as well as VIs.
(3,850 Views)
One possibility is the FP.IsFrontmost property of VIs. If you check whether it's false for all the open VIs.
(3,850 Views)
That can work, but in my application I have nearly 800 VIs in memory, so opening a reference to all of them and checking the property for each one over and over is quite inefficient.
(3,850 Views)
I also ran into this issue. The previous post can be solved easily by the new event structures, but I need to check if a panel is the frontmost in windows as well.
The FP.Is frontmost property returns if a panel is the frontmost Vi within Labview but not if Labview is the frontmost window in windows.
I ran into this as I am making some stuff to use the scollwheel.
As an example I have added two Vi's. Just load & run these, as long as Labview is active this works. But I would like to have something that switches the lights off when I select another Windows application.
I (think I) cannot use the USER32.dll API as I reconstruct a reference to the 'owner vi' using a control reference.
Anyone has some experience with this??
25+ years long fan of LabVIEW. Move to Emerson looks to be for the better! See the last posts in subscription model thread.
(3,469 Views)
