Different Time interval between event firing
Hi friends, i am trying to implement "Morse Telegraph Machine" by using event structure. But i am facing a problem with assigning time interval between the event firing. when i type two characters with 50 m. Seconds interval the two characters should form into a word, and with 200 m.seconds interval the two characters should form as two separate words. but i couldnt find a way to assign the time intervals between the events. if anyone can knows how please help me
(3,124 Views)
Not sure what "events" are in your context. Are you using an event structure? Feel free to post what you have.
If you are using an event structure, you can specify the time out event. An event case can put the new time out time, put it in a shift register, and the event structure can use that for the new time out time.
(3,108 Views)
it is better to use the queue
Labview 4.0, 5.0, 6.1, 8.6, 2009, 2011, 2012, 2014
If you do not know something, ask me.
(3,084 Views)
use the 'time' in whatever event case that you use to handle the key press to compare its current value and previous value.
-Joe
(3,060 Views)
