04-01-2019 09:39 AM
This question was first posted as a followup (here) - but it clearly is a separate issue that warrants a new question. You can see some background info there, however.
I've created a simple VI which demonstrates the issue. It's attached, as is a built version of the application.
This VI uses the Windows API to create a live feed from a USB webcam, it then allows the user to save a still from the camera to a chosen location. It was created as a workaround for a project that can't afford the runtime license for NI's IMAQ drivers, let alone a development license for them.
The image save is achieved by copying the webcam feed at a given point in time, and then fetching the copy from the clipboard in order to get a savable image.
This works very well when the VI is run from within LabVIEW's development environment, however it consistently fails when run as a built executable.
It appears to be the saving that is failing overall. Debug indicators suggest that something about the interaction between copy & Clipboard.Get Image is wrong. I don't think it's a race condition however, as I've been quite careful with the wiring with respect to that, I've also looked into it a bit already - which I'll explain a bit below.
Any help anyone can offer would be greatly appreciated!
**Further info from my debugging efforts below, not required reading!**
I'll do my best to describe what I've found so far by watching debug indicators, but it'll be easiest to see by just running the VI:
If the clipboard is empty:
- No image is saved
- Indicators show no image is fetched from the clipboard
- Opening paint and pasting produces the image that should have been saved
-> I'd think "Oh, clearly the copy is happening after the paste" however, if I then tried again I'd expect:
-The previous image to be saved
-Indicators showing the previous image
However, the behaviour is exactly the same as the first attempt.
If the clipboard has something in it already (a string or something - I think specifically if it was copied from within the application...):
- An image of the previously copied item is saved
- Indicators show an image of the previously copied item
- Pasting into paint afterwards produces the image that should have been saved.
->As before, instead of the expected behaviour if this were due to a race condition, instead when trying again I get:
- An image of the previously copied item saved again.
- Indicators still showing an image of the previously copied item
- Pasting into paint produces the new image that should have been saved...
Solved! Go to Solution.
04-01-2019 09:01 PM
I think you might be out of luck using the Clipboard:Get Image function. The help for the function states it doesn't work in the RTE:
You may be able to use some other method of querying the clipboard (.NET?), but I'm unsure off the top of my head.
04-02-2019 03:08 AM
Thank you very much, Michael! I'm surprised I missed that...
This certainly gives me an avenue to explore at least!
04-02-2019 03:22 AM
I wonder if you could just flatten the image data to a string and use the Clipboard Read and Write methods? Those seem to be supported under the RTE.
04-02-2019 03:29 AM - edited 04-02-2019 03:30 AM
I've just found this: someone's .NET workaround for this exact issue.
Later in the thread the marked solution states that a change in execution is also required.
I'll try it now and see if it makes a difference!
04-02-2019 04:59 AM
For future reference, the attached project / build works nicely.
Note that under Take Snapshot.vi's VI Properties->Execution, Preferred Execution System is set to User Interface. This is required for the .NET Image.Save call to work.
Thanks for the help!
