‎05-18-2013 12:31 AM
Hello all,
If in serial communication I have to write and read muliple times (In same VI) but the condition is for each write and read there is different timeouts then is it compulsory to initialize the serial port number of read / write times or there is another alternative.
for example say I need to perform three read / write operation.
1. Write a read b - timeout is 1 sec.
2. Write c read d - timeout is 3 sec.
3. Write e read f - timeout is 10 sec.
In above example a,b,c,d,e,f is just an example.
‎05-18-2013 12:41 AM
You can change the timeout just by using a property node. No need to reinitialize everything.
‎05-18-2013 12:47 AM
Will it work if I do this immediately after first write and read and before second write ?
‎05-18-2013 08:15 AM
yep
