Different versions of instrument drivers
Hi
Are labVIEW drivers version specific?
if I have a non-NI instrument and the only driver available is for labVIEW version 8.2 for examble, can this driver operate with newer versions of labVIEW such as 8.6 , 2009 , and 2010.
(3,359 Views)
Accepted by L Vate
Yes, it will work. It just needs to be recompiled and resaved for the new version. Just open the VIs in the new version and resave them. Make sure you have a backup of the original.
(3,337 Views)
Thank you smercurio_fc f f
(3,316 Views)
Just doing the mass compile would answer your question.
(3,305 Views)
