Different versions of instrument drivers
Hi
Are labVIEW drivers version specific?
if I have a non-NI instrument and the only driver available is for labVIEW version 8.2 for examble, can this driver operate with newer versions of labVIEW such as 8.6 , 2009 , and 2010.
(3,351 Views)
Accepted by topic author L Vate
Yes, it will work. It just needs to be recompiled and resaved for the new version. Just open the VIs in the new version and resave them. Make sure you have a backup of the original.
(3,329 Views)
Thank you smercurio_fc f f
(3,308 Views)
Just doing the mass compile would answer your question.
(3,297 Views)
