Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Differents records in Datalog File
Zen
Member
06-21-2002
10:38 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hello
In LV, how to create a dtalog file containing two (or more) differents
sequences of identically structured records?
I want to save in the same file 10 cluester (made of 1 string and 1
Boolean) and 3 double-precision reals.
Thanks.
0
Kudos
Message
1
of 2
(2,571 Views)
Reply
Re: Differents records in Datalog File
Alberto
Active Participant
06-21-2002
11:12 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Zen,
I attach a LLB in which you find 2 vis to write and read DLG files,and relative sub-vis.
If you change the cluster structure, you must change it also in all sub-vis.
Good luck,
Alberto
datalog.zip 117 KB
0
Kudos
Message
2
of 2
(2,571 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
