Differents records in Datalog File
Hello
In LV, how to create a dtalog file containing two (or more) differents
sequences of identically structured records?
I want to save in the same file 10 cluester (made of 1 string and 1
Boolean) and 3 double-precision reals.
Thanks.
(2,572 Views)
Hi Zen,
I attach a LLB in which you find 2 vis to write and read DLG files,and relative sub-vis.
If you change the cluster structure, you must change it also in all sub-vis.
Good luck,
Alberto
(2,572 Views)
