Digital Output Signal from NI9401
Hi everyone,
I am new to the labview programming and I am using the CDAQ 9178 together with the NI9401 modules to collect signal/output signals. I was able to collect signal from my hardware at a rate of around 6000 per 100ms. (60kHz) However, when I want to output a digital signal at 60kHz, I was unable to do so? Are there ways to generate a 60kHz or more digital pulse output signal from the NI9401? As what I understand the specifications state the max Frequency is 20MHz for 2 channels which is what I am using. Currently I was only able to generate a max frequency output signal of 5Hz.
Hope someone could give me some advice? Thanks everyone.
Jhao
Message 1 of 1
(2,432 Views)
