Digital Output and Digital Input tasks at same time using NI 9403 at cDAQ
I am trying to write a Labview program that can provide digital output signals (DO) and can read voltages (DI) at same time.
I have cDAQ 9174, and a DIO module NI 9403.
For NI 9403,
line 0:3 provide the DO for a motor translation.
line 4 reads the voltage (DI) from an sensor that can decide whenever I should stop the motor to avoid motor damage.
I am wondering if I could  use this single module (9403) to achieve DO and DI at same time? And how to handle the sampling rate for the two different tasks?
Thanks for the help!
(4,268 Views)
https://www.ni.com/pdf/manuals/374069a_02.pdf
     "In an NI CompactDAQ chassis, you can use the NI 9403 as only a static (software-timed) digital I/O module".
Digital lines can be used independently (run in parallel simple digital input and output examples for separate lines (not port)), but at low rate (hundreds Hz, software timed loop).
If it is stepper motor, might work in not critical application, without smooth speed control. You can run clock task in one loop and switch "enable", "direction" only when you need them.
(4,228 Views)
Hi Alex,
Thanks for your reply.
I tried DO and DI at a very low rate 50Hz, and it is not working. Also, I need a fast motor translation, and 1.5k Hz at least. Now I am considering the analog input module (NI 9201) for sensor reading.
May I ask if this SINGLE AI module can provide two AI tasks? (One for my other device, and one for sensor readings at different rate)
Elliot
(3,906 Views)
Accepted by ElliotYY
Hi Elliot,
No, the NI9201 uses a MUX to switch between its 8 channels. So it does not support sharing that single MUX between several DAQmx tasks…
(3,900 Views)
Sample both at the higher rate in one task and downsample the slow one.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,898 Views)
Yes. It works for me. I combined the two AI tasks to a single task at high rate.
Thanks a lot!
Elliot
(3,864 Views)
