Digital-SW-Timed Output using a 'waveform' data
Hi. I'm trying to send a waveform data to a digital channel.
I slightly modified the example 'Digital - SW-Timed Output', which is for a single data, to accommodate a waveform data. The code is attached.
The modified code doesn't look to output any signal (checked with an oscilloscope). Can you please tell what I am missing?
Message 1 of 8
(4,141 Views)
Hi 3doptics,
it doesn't make sense to output a whole waveform to a SW-timed DO pin.
Try this to output one sample after the other:
(Maybe you need to set the autostart flag at DAQmxWrite or reposition the DAQmxStart call: usually you write a waveform before starting the task.)
Message 2 of 8
(4,083 Views)
Hi GerdW,
Thank you for providing the solution.
I believe the solution you suggested achieves a different goal from what I was trying to do.
I was trying to send a trigger signal (defined as a waveform '010') from the Labview program to an external device through a DO channel. The time interval between the data points of the waveform (dt) should be different from the time interval between the trigger signals, which is set by the 'Wait' function in the for loop.
Could the 'Digial-SW-Timed Output' be used (after some modification) for this purpose, or would I have to use a completely different approach?
3doptics
Message 3 of 8
(4,074 Views)
Hi 3doptics,
I guess you need to use a different approach: the DAQmx task will output the waveform again and again (by default) independently how often (and when) you rewrite the data buffer! When you want to output a short waveform at defined times you need to
  1. output the data one time
  2. then stop the task and restart when needed (this will takes it's own time for reconfiguring!)
  3. or put the DAQmx task on hold and re-arm when needed (less time needed because you don't need to reconfigure the DAQmx task)
Message 4 of 8
(4,057 Views)
Hi GerdW,
Thank you for your time and suggestion.
Could you please tell which functions allow to "put the DAQmx task on hold and re-arm"?
To illustrate what I was trying to do, I have uploaded a vi (and a screen capture). With this, I could go up to 500 Hz. It solves my problem, although it's far from being elegant.
3doptics
Message 5 of 8
(4,045 Views)
Hi 3doptics,
Having a loop spinning 100k times for 4ms per iteration lets the user wait for 400s (or ~7mins). Quite a long time…
Your device is connected via USB and you are trying to send commands at 1kHz command rate (1ms wait for each frame): this will not work reliable using the USB2 connection of your DAQ device on a standard Windows computer…
Read this article from LabVIEW help on DAQmx task state model. (It's linked from the DAQmxControlTask function description…)
Message 6 of 8
(4,041 Views)
Hi GerdW,
Yeah, that was an example file written for a demonstration purpose. The parameters will be adjusted when the code is incorporated into another main code. I'm using a NI DAQ board, so I assume 1 kHz may be OK, even though I'm not sure how the Windows will handle it. It looks OK at least on an oscilloscope.
Thank yo for sending the link.
3doptics
Message 7 of 8
(4,030 Views)
Hi 3doptics,
I was mixing this with some other discussion in a different thread: is your DAQ device connected by USB or do you use some built-in DAQ card (PCI(e))?
In case of USB this would be the bottleneck…
Message 8 of 8
(4,025 Views)
