MKS PR4000B reply equals command
Dear friends of LabView,
i am trying to control 2 MFCs with a MKS PR4000 using the driver provided by MKS. Setting a setpoint works fine, however when i try to read out the actual flow i get the command as a response (?AV1<CR> -> ?AV1). Does anyone have an idea what is going on?
Phillip
Message 1 of 8
(4,997 Views)
That should be in the manual, specifically in the communication chapter.
Some devices echo the command if it's incorrect (again, better check the spec). If a working command doesn't echo, that might be what's happening.
I'd have a look, but the manufacturer makes me register (*sigh*).
Message 2 of 8
(4,978 Views)
Here is the manual. In case of an error it is supposed to give an error code not echo the command as far as i see it.
Message 3 of 8
(4,973 Views)
Can you look in the driver VI?
Who made the driver? They should know...
Message 4 of 8
(4,966 Views)
Accepted by topic author PTimmer
Te Driver is from the 90s and very simple. When i send the command via 232analyzer i get the same result. So never mind its a device issue. Thanks for everyones help tho.
Message 5 of 8
(4,952 Views)
+1 for keeping us informed and posting\accepting a solution.
Message 6 of 8
(4,942 Views)
Smiley LOL Thanks mate.
Message 7 of 8
(4,921 Views)
I would drop the question mark (AV1[cr] )but would use it as shown when asking value of setpt.
Message 8 of 8
(4,613 Views)
