Digital output multiple channels with multiple samples
I am writing a LabVIEW program to generate 4 channels (line2:5) digital outputs. Each channel has multiple samples. However, except line2, line 3:5 has no signals. Can anyone help to check what the problem is?
Both of my VI and screenshot were attached here.
Thanks a lot,
Elliot
(7,440 Views)
Put a probe on the array that's inputting the signals to DAQmx Write. All of the lines except for the first one are at 5 all the time, so lines 3:5 are just a constant "5".
Also, you don't write Boolean data to lines like that, it's trying to write it to a Port. Writing 0 and 5 don't make it go to 0V and 5V. You can only write True or False to a Line, so even if the 5's are changing it won't work. Note that the mode is "Port format", which means each integer is trying to write to a whole Port. For example, a U8 would correspond to 8 different Lines in a Port, so 0b00100110 would write a True to lines 1, 2, and 6.
Look in Help -> Example Finder -> Hardware I/O -> DAQmx -> Digital Output for some example code you can copy.
(7,421 Views)
Hi  BertMcMahan,
Thanks for your reply.
For DAQmx digital boolean write, I did NOT see an option like "multiple channels multiple samples boolean array in DAQmx Write.
I tried a simple scheme of writing one channel (line2) with 0101.....(TTL) at a specified sampling rate. I also did NOT see "single channels multiple samples boolean array" in DAQmx Write. Any advice to do this?
(7,332 Views)
Accepted by ElliotYY
If you can place all of the lines you need in a single channel (by setting the Create Virtual Channel as "One channel for all lines", then the following should do what you want:
Boolean Array to Digital WaveformBoolean Array to Digital Waveform
If you can't do this, then you need a waveform for each channel, and you could modify the code to the following:
Add a For loop to create an array of waveformsAdd a For loop to create an array of waveforms
In this case, I added an extra Build Array inside the For loop, because the Boolean Array to Digital Waveform requires a 2D array, and the columns give lines (a new row gives the next value, hence the transposes).
(7,320 Views)
Awesome. This works perfect for me.
Thanks a lot for your help!
(7,281 Views)
