03-13-2024 11:35 AM
Hey there I had inserted a switch button but is acting like a push button , in other code using daqmx assitance both act like a siwitch button.
Solved! Go to Solution.
03-13-2024 11:45 AM
Right click on the boolean control and select from the mechanical action options, play with them until you find what you are lokking for.
03-13-2024 11:51 AM
Just your short description and screenshot are not really easy to be sure, but it kind of sounds like you need to set a different mechanical action for your button:
NI Help page:
Wiki page, which has a better description of the options:
https://labviewwiki.org/wiki/Boolean_controls
