Digital output
Hey there I had inserted a switch button but is acting like a push button , in other code using daqmx assitance both act like a siwitch button.
(10,812 Views)
Accepted by topic author Chris9823Alb
Right click on the boolean control and select from the mechanical action options, play with them until you find what you are lokking for.
(10,805 Views)
Just your short description and screenshot are not really easy to be sure, but it kind of sounds like you need to set a different mechanical action for your button:
NI Help page:
https://www.ni.com/docs/en-US/bundle/labview/page/changing-the-mechanical-action-of-a-boolean-object...
Wiki page, which has a better description of the options:
https://labviewwiki.org/wiki/Boolean_controls
(10,797 Views)
