Digital signal to oscilloscope?
I am trying to create a digital signal and view it with the oscilloscope. I have started with an analog one, converted it with DWDT Analog to Digital and when I am trying to connect it with the oscilloscope (DAQ Assistant) via the NI PXIe-6363 card and SCB-68A connector, I have the following error:
What is wrong with my design?
Thanx a lot in advance!
(3,228 Views)
You're simulating an analog signal and the DAQ Assistant is configured to output a digital signal.
To create a digital waveform, look for an example or checkout functions available in 'Digital Waveform VIs and Functions' sub-palette.
Digital Waveform Palette
Or you can also think of spending some money on buying 'NI Digital Waveform Editor'.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,222 Views)
Thank you for the fast reply. I thought that there was a conversion to digital form. So in that way, which element should I use to create a digital signal and observe it with the oscilloscope. I tried 'Build wavform' and 'Build digital' modules but none worked!
Thank you
(3,208 Views)
The error tells you exactly what is wrong.  The DAQ Assistant is looking for a 1D Array of Digital Waveform.  You are just giving it a scaler Digital Waveform.  So throw in a Build Array resized to only one input.
(3,205 Views)
