Ding sound when I Export Picture Image
Hi All,
I am using 'Export Image' Invoke function of Picture control to export Picture control's data to Clipboard. The function performs as it is intended to but in 64 bit version of LabVIEW, I hear a ding when I use this function. I do not hear any ding in the 32 bit version. Also, there is no ding in the development mode, I only hear it in the 64 bit EXE.
Is this a bug?
Message 1 of 9
(3,582 Views)
I have a couple questions that may help narrow down troubleshooting.  Do you hear the ding on the 64-bit executable on other machines too or just the development machine?  Also how have you determined that the invoke node is the part of the code causing the ding?
Message 2 of 9
(3,497 Views)
Yes, I hear Ding on all the other machines I run the executable.
I removed invoke node from the code and did not hear any Ding in the EXE.
Message 3 of 9
(3,482 Views)
Somewhere I posted code to momentarily turn off a sound, but that is probably like pulling the bulb from your check engine light.  Does the code work despite the ding?
Message 4 of 9
(3,460 Views)
Yes, the code works despite the ding.
Message 5 of 9
(3,448 Views)
It does seem strange you are hearing a ding.  I would like to see if I get the same result on my machine.  It looks like you are using LabVIEW 2013, correct?  And which OS?
Message 6 of 9
(3,346 Views)
I am using LabVIEW 2012 SP1 on Win 7.
Message 7 of 9
(3,327 Views)
Just wanted to let you know I found the same result as you.
This was reported to R&D (# CAR 444840) for further investigation.  Thanks for the feedback!
Message 8 of 9
(3,298 Views)
Thanks for reporting it to R&D team.
Message 9 of 9
(3,260 Views)
