Multiple Variable Editor
It will result very useful to add some features to the Multiple Variable Editor to create or replicate variables.
Features I'd like to propose are the followings:
  • cut and paste between two different editor instances (imagine to have two expansion boards with similar variables, you create one then copy and paste them to the other)
  • find and replace name with patterns (to modify subsets, prefix or whatsoever of the variables...)
  • ability to export to Excel the table, for documentation.
MaurizioBollini
Maurizio Bollini
Certified LabVIEW Architect
http://www.met.it
https://www.linkedin.com/in/mauriziobollini/
(3,441 Views)
Hi Maurizio,
you might think about posting that idea in the LabVIEW Idea thread...
(3,434 Views)
When you talk about variables, what are you then refering to?
Is it Shared Variable, Global Variable or Local Variable ?
(3,398 Views)
