Direct print to LPT1
Has anyone managed to get a direct (raw) print to LPT1 ?
Ive tried using the outp function, but no joy..
Rgds
Andy
(4,668 Views)
Hallo, Andy,
Du meintest am 16.08.99 zum Thema Direct print to LPT1:
Printing to LPTx uses handshaking. You have to serve these handshake
lines.
And you should take care of the "paper end" signal ...
Viele Gruesse!
Helmut
(4,333 Views)
You can find details in an NIWeek presentation from two years ago.
You can use serial port VIs to output bytes to LPT1, or you can
use a DOS window to redirect a file with something like "type
output.txt > lpt1" or "copy output.txt lpt1". There are some
tricks having to do with getting the DOS window to work and
getting the serial configuration setup in the .ini file.
Greg McKaskle
(4,333 Views)
Hi
Can you possible direct me to the information, I cannot find it on the NI
website
(I may be being blind here...but had a good look around and searched )
andy
BTW, I am not using VI's, im using CVI
Greg McKaskle wrote in message
news:37B8C07C.77E168BE@austin.rr.com...
> Gr
eg McKaskle
(4,333 Views)
> website
I searched too and didn't find anything on the web site. I know the
presentation was presented; so you may need to ask about it.
Greg McKaskle
(4,333 Views)
