Tree Control ActiveX and the Runtime - help...
We've build a BridgeView application that lets you select past datasets
using a tree control. It works fine when the BV development system is
installed, but when we remove it and replace it with a Run-time
version, the control is no longer visible or active....
TIA,
Thor Johnson
thor@randombytes.com
www.advance-it.com
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
Message 1 of 1
(3,723 Views)
