Directx with Labview
Hi guys
I have to do an assignment at Labview, but I do not know how to start or where is the right path. I need some help pls
My job is to combine the activX function with the DirectX program so that the two can run together on one PC to display a full screen mode with several forms, for example circle that moves left and right, or for example what can be seen here in the following video.
https://youtu.be/CG5n516PCXM
This should be shown in a single window and the dialog should be shown in the other window.
Can someone help me
(2,436 Views)
Hi SulimanKasem,
Is your goal to play some pre-recorded video(media file) on Labview? I am not sure if this helps but home these links could give you a clearer direction on how to start. There are also some related example codes you can try have a look at.
1. https://forums.ni.com/t5/LabVIEW/I-have-some-problem-about-directX-When-I-play-avi-on-labview/td-p/1...
2. https://forums.ni.com/t5/forums/searchpage/tab/message?profile.language=ko&q=activex%20quicktime#mes...
3. https://forums.ni.com/t5/forums/searchpage/tab/message?q=activex%20VLC&page=2&collapse_discussion=tr...
4. https://forums.ni.com/t5/forums/searchpage/tab/message?profile.language=ko&location=Board:170&q=acti...
(2,366 Views)
