How to change vi's ctrl from C/C++ DLLs in LabVIEW(在dll中执行过程中如何改变labview控件值等)
Calling C/C++ DLLs  in LabView, and change Labview in DLLs.
For example,change panel control's value or run a vi and so on
(Labview调用dll时,dll可能同步反馈数据,需要改变面板某个控制值,或运行某个vi,类似回调函数功能,如何实现)
(1,929 Views)
What is the question here?
Rolf Kalbermatter  My Blog
(1,882 Views)
If action is very long in DLL,how to real time change value of ctrl befor the end of the DLL
(1,839 Views)
Accepted by topic author iori_007
You can't access controls from inside a C DLL directly with any officially documented API. What you can do is however to call PostLVUserEvent to send an user event to your applications user event structure and let it respond to that. That requires of course that the call to the DLL function that blocks for this long time is not inside the same loop as your applications event loop and that you made your DLL function multithreading safe as you can't call it in the UI thread context, otherwise your GUI won't be able to update the change on the front panel until your function returns anyhow.
(1,818 Views)
