Disable Numeric Control Increment/Decrement with arrow keys?
Is there a way to disable the increment/decrement for numeric controls from the arrow keys? I have an array of scale factors that I don't want the arrow keys to increment/decrement the scale factor if the user tries to navigate with the up/down keys.
Message 1 of 10
(6,754 Views)
Accepted by topic author adekruif
You could use a Key Down? event for the controls and discard the event if it happens to be an up or down arryw.
Message 2 of 10
(6,736 Views)
You may also hide the arrows: just open the control's context menu and uncheck Visible Items -> Increment/Decrement.
There's a Control property to do this programatically, too.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 3 of 10
(6,669 Views)
That does not affect the keyboard arrow keys, which is what I think the OP is asking about.  But I still disable the Increment/Decrement arrows in all of my UI.
Message 4 of 10
(6,641 Views)
You're right. I misinterpreted the OP request.
Paolo
Message 5 of 10
(6,629 Views)
If you have an event case and check for Key Down you can at least set a flag to undo the next event, which will be the Change Value.
Message 6 of 10
(6,624 Views)
Hi Ramon,
no need to store a flag when you use a filter event (like "KeyDown?") and discard the event for "unwanted" keys:
Message 7 of 10
(6,617 Views)
@GerdW wrote:
Hi Ramon,
This is what I was trying to accomplish but couldn't get it to work as intended without the discard filter. I hadn't filtered anything before so I didn't know the option was available. Thanks everyone for the help!!
Message 8 of 10
(6,598 Views)
Hi Gerd,
I forgot about that option, which is even better. However for me the "KeyDown?" event does not seem to be triggered on an array of numerics like the OP was asking for.
Message 9 of 10
(6,587 Views)
@RamonG  ha scritto:
Hi Gerd,
In case you have an array, you need to register the event with the Array Element reference:
Paolo
Message 10 of 10
(6,561 Views)
