Disable Right Click Menu
I want to disable the right click menu for all the controls in my front panel.
I know that we can right click each of them individually and disable it.
But is there any other way of doing it all at once?
Thanks...
Message Edited by manojpcw on 06-03-2009 09:03 AM
Message Edited by manojpcw on 06-03-2009 09:04 AM
(11,005 Views)
Accepted by manojpcw
Unfortunatly you cannot do this programmatically but you can disable runt-time menus for the whole VI in VI Properties >> Windows Appereance >> Customize....
Message Edited by waldemar.hersacher on 06-03-2009 04:16 PM
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(10,990 Views)
Maybe there is more simple but it should work : I use the filter event "Pane : Mouse Down?" and check which button was clicked (if it is "right button", anywhere on panel, the event is discarded).
(10,987 Views)
Waldemar solution is more simple indeed !
(10,985 Views)
VI Properties > Window Appearance > Customise > Allow Default Run-Time Shortcut Menus
Update - Wow! At the time of writing my response there were no others! Waldermar truly beat me to it Smiley Very Happy
Message Edited by Thoric on 06-03-2009 03:20 PM
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(10,984 Views)
Hi manojpcw,
i didn't found  a property or a method to do it with the reference, but you can use an event structure with the event "shortcut menu activation?". You can then discard this event. If you need it for a lot of controls, then you can register this event dynamically.
Hope it helps.
Mike
(10,978 Views)
