Disable "About this example" dialog - Teststand Simple Interface LabVIEW
<TestStand Public>\UserInterfaces\Simple\LabVIEW\Source Code\TestExec.llb\Simple OI - Top-Level VI.vi
Hi - I have been looking into above LabVIEW project and have made some amendments - Where I am failing miserably is to locate and disable the "About" dialog as below - Any ideas please on where this might be ?
Many Thanks
(593 Views)
Accepted by topic author sal23
The popup is coming from the sequence file you have open, not the LabVIEW interface.
The 'Computer Motherboard Test Sequence' .seq file has a SequenceFileLoad callback with a popup that shows when the sequence opens:
It's possible that the LabVIEW interface remembers the last open sequence file, and automatically loads this example again every time you open the interface. Try openning a different .seq file or clearing the LabVIEW interface history.
(553 Views)
Great Thanks - I see it now - even though I fixed the sequence outcome would still be the same - I had to "Close Sequence" and reopen it.
(530 Views)
