> I'm very interested in disabling the cursor scroll capability but I'm
> confused by your answer.  I've never seen the item you are talking
> about in any graph in LabView 6i.  Can you be a little more
> descriptive?  I tried to find it in every graph I have in the Graph
> Pallette, to no avail.  Labview does give you the ability to lock the
> cursor to the plot, but users can still mess up the X and Y axises if
> they drag their cursor a little to far.  Please be more specific in
> your fix to this problem.
I could be confused by the version number.  The item is definitely in
6.1.  Popup on a graph, the plot area is probably the largest and
easiest to hit.  Go to the Advanced item and see what is there.  The
bottom item in my version
 can be checked or unchecked to enable and
disable scrolling when a cursor gets to the edge of the graph.
If you do not have the menu item, add the following to your .ini file.
scrollGraphCursors= FALSE;
or
scrollGraphCursors: FALSE;
depending on your platform.
Greg McKaskle
