closing runtime causes dr.watson (only LV6.0.x)
When I run my application (LV 6.0.2) on a Win NT system and close the application window, I get a Dr.Watson Error. Stopping the Application without closing the window causes no error. The error occures only in communication with my CAN-Interface. LabView 5.1.1 causes no error.
(2,770 Views)
Hello:
What is the NI-CAN driver version that you have? I hope you have the latest CAN driver available from ni.com > Support > Product Reference > Drivers and Updates > Current Versions.
By application do you mean you are running it as a stand-alone exe generated through LV. I ask since you mentioned "closing runtime" in the subject. Is this behavior the same on a different machine too? Do you have LV 5.1.1 and LV 6.0.2 on the same machine.
Does Dr.Watson have any description associated with it? Please provide some more information.
Pavan B.
(2,770 Views)
Helo:
The CAN-driver I use, is no NI-driver.
Yes, the application is a stand-alone exe generated by LV. I have no LV on the System, only the application (because of disk space).
Dr.Watson describes (in German):
"Zugriffsverletzung (0x00000005), Adresse: 0x037bae6c
(2,770 Views)
Do you mean CIN? to make our CAN boards work, you need a driver.
Looks like you have a runtime engine (RTE) dll for 5.1 and not 6.0.2? you can check this by looking at the version for file lvrt.dll. Are you including the RTE with your application?
(2,770 Views)
