Disable single column of Table
Hi All,
This may be something very silly to ask.
Have a Table control in which first two column would not be editable by the user and remaining would be user entry.
How do I go about disabling only two columns of the table control?
Thanks in advance.
Message 1 of 8
(5,894 Views)
As far I know you cannot do that. But a simple workaround would be is to have 2 seperate Table/Array and make the 1st disabled (make it as an indicator) and have the second one editable. Tricky part is to decorate them and make it look like a single table. Does it make sense?
Message 2 of 8
(5,877 Views)
Hi NaruF1
May be you can tri the attachd VI.
Please tell me if this works
Kudos are expected
Ninad
Ninad Regundwar
Junior Engineer | ARAV Technologies | www.aravtech.com
Message 3 of 8
(5,873 Views)
Please attach the code in 2011 version.
Message 4 of 8
(5,870 Views)
Hi P@Anand
Please check the attached code
Ninad Regundwar
Message 5 of 8
(5,866 Views)
Accepted by NarayananK
The attached code disables the first two rows but, to change it to columns just change the unbundle value to column.
Ninad Regundwar
Message 6 of 8
(5,862 Views)
Hi ninadskr419,
Thanks for the vi. Believe some easier way of doing this could be available.
But does the job as of now.
Message 7 of 8
(5,843 Views)
Hi Naru,
put a decoration (like rectangle) on top of the table so that it covers the first two columns. Make the decoration transparent and you're done...
Message 8 of 8
(5,841 Views)
