Disable single column of Table
Hi All,
This may be something very silly to ask.
Have a Table control in which first two column would not be editable by the user and remaining would be user entry.
How do I go about disabling only two columns of the table control?
Thanks in advance.
Message 1 of 8
(5,989 Views)
As far I know you cannot do that. But a simple workaround would be is to have 2 seperate Table/Array and make the 1st disabled (make it as an indicator) and have the second one editable. Tricky part is to decorate them and make it look like a single table. Does it make sense?
Message 2 of 8
(5,972 Views)
Hi NaruF1
May be you can tri the attachd VI.
Please tell me if this works
Kudos are expected
Ninad
Ninad Regundwar
Junior Engineer | ARAV Technologies | www.aravtech.com
Message 3 of 8
(5,968 Views)
Please attach the code in 2011 version.
Message 4 of 8
(5,965 Views)
Hi P@Anand
Please check the attached code
Ninad Regundwar
Message 5 of 8
(5,961 Views)
Accepted by topic author NarayananK
The attached code disables the first two rows but, to change it to columns just change the unbundle value to column.
Ninad Regundwar
Message 6 of 8
(5,957 Views)
Hi ninadskr419,
Thanks for the vi. Believe some easier way of doing this could be available.
But does the job as of now.
Message 7 of 8
(5,938 Views)
Hi Naru,
put a decoration (like rectangle) on top of the table so that it covers the first two columns. Make the decoration transparent and you're done...
Message 8 of 8
(5,936 Views)
