03-29-2012 12:07 PM
The help for the Disabled Property Node of a control says:
| 0 | Disabled—The object appears as normal on the front panel, but the user cannot operate the object. |
| 1 | Disabled and Grayed Out—The object appears dimmed on the front panel, and the user cannot operate the object. |
| 2 | Enabled—The user can operate the object. |
However, this seems to be incorrect, as the value 0 means that the control is Enabled, 1 is Disabled and 2 is Disabled and Greyed out.
Not a big thing, but worth mentioning in case it has not been corrected.
Cheers,
Paolo
03-29-2012 12:27 PM
The documentation was corrected in subsequent versions of LabVIEW.
03-29-2012 12:27 PM
good to know.
