Help me capture image with USB camera
Hi. I need TO Capture and save image with USB camera of edmund optics, I already could  to get the vision of camera with IMAQ vision. But, i must take images with camera with external enable. I have two strings; with one I take image and with other I Not take image.
I need Know if you can help mewith this. I needKnow how can enable the image capture when I have the string for take image
¿how can anable a camera take image and save this image with One conditional loop change of state and therefore i Get string for take image ?
(2,795 Views)
That you need is set the property node of the image display to make it visible or invisible. This an example
(2,787 Views)
I haven't all drivers that you are using in example. can you tell me which you used?.. wath drivers of IMAQ?.. My Labview did not find some
(2,783 Views)
